Webos 6.00.30
The other day my 2017 oped panel had a firmware upgrade from 6.00.25 to 6.00.30, curious anyone have any info on what this actually did. My theory is it relates to advertising, or have they closed off the webos sideloading, I cant fijd any info on it at all
Sorry no idea, but i thought the same re advertising. Nothing on their website and when contacted LG directly was advised they don't comment or provide details on update contents.. which i found very strange. They did claim it had nothing to do with new data collection processes but wouldn't respond further when pressed. Would appreciate some advice on this from an LG tech
    • By Prakash Sahoo
      Hi Team,
      Prakash Sahoo
    • By Jaswinder Sandhu
    • By tarakdave
    • By AtWitsEnd696
