Standard Remote Control
I just did the initial set up yesterday for LG 55UQ7570PUJ.  I discovered that the user information I have found refers mostly to the "magic" remote
and I have a standard. Will I still have decent functionality?  I have AT&T U-verse and I have to switch to the cable remote to change channels.
Is it possible I can get things set up to use one or the other remote? A tech told me over the phone I'd either need the magic remote, or I'd need to contact
the cable provider. I don't think my model supports the magic remote. This is my first Smart TV experience. Can someone take me by the hand
and get me over the fear that I won't be able to figure things out?
Thank You.
    • By crct
    • By JasonB
    • By David Daul
    • By RJ Fischer
    • By Regis Wheeler
