Distorted picture
    • By herebedragons69
      I purchased an LG 86" UT8050 4K UHD LED Smart TV (2024) from JBHIFI in Australia. The TV was wall-mounted and set up by a local installer. I discovered that my TV has Chromecast built-in. I tried casting music from Roon, but Chrome immediately crashed and the TV shutdown. I tried again and the audio was distorted. I shut down and tried again and the audio stuttered. I tried Chromecasting with Qobuz and Plex and got the same result on audio playing out to my Yamaha RX-V6A and the TV speakers. I then tried to play audio from the Plex App in the LG WebOS. That played fine, without any distortion.
      Thinking this might have been a result of a hurried setup (the installer did this job "on the run" I reset the TV to factory defaults and set it up again. Everything went smoothly. But the problem with Chromecast persists. First time launching Chromecast the app crashed and the TV shutdown. 2nd try I got distorted audio to the receiver and to the TV speakers. Audio and Video are fine on all other apps. I can see no other faults.
      I've been Googling this and not seeing much info other than a few threads where people are saying that the LG built-in Chromecast feature does not work. I saw that one person returned his TV and the replacement had the same issue with built-in Chromecast. Most discussions on this issue are hijacked by people using a Chromecast streamer or dongle as opposed to the built-in Chromecast. They often talk about turning off this or that specific Chromecast setting, settings that are not accessible with a TV with built in Chromecast
      In the WebOs when I look at connected source devices Chromecast is there with a "Chromecast Settings" option. The settings have only one option and that is opt-in on sending crash data to Google. Apparently, Google is not monitoring the issue very closely.
      I listen to mostly Hi-Res audio. I wonder if the issue is caused by the bitrate of 24-bit Hi Res flac files. I did notice that when I cast audio that was CD quality (16-bit), the distortion did not occur. This is weird though because in the past I have been able to cast 24-bit audio to Chromecast-enabled devices without any problems.
      My TV says my firmware is up to date. I did not see a prompt to install a firmware update during setup. I've set software and app updates to be automatic.
      Appreciate any help or even a "Hey, it's not just you, this is a known issue, I've got this problem too".
    • By Low Grade
      many thanks in advance😃
    • By NEIL_Auburn
      I have a COMPOSITE signal from a VCR that passes through a DENON AVR to my LG OLED at the composite connector (red, white, yellow) on the TV.
      I think it had displayed video in past use. But now it does not.  TV home shows AV1 connected.  Screen goes BLACK (hint?)  Then if yellow video plug disconnected, MSG from OS shows "NO SIGNAL CHECK INPUTS."
      I think TV thinks a signal is applied when the video cable is plugged in but somehow doesn't display the program!!!
      I have confirmed good video signal on cable direct from devices and from DENON with a portable TV!!
      So, what might be setup up wrong or failed in my OLED TV setup???
      Any help will be appreciated.
         Neil
      Powered by the α8 AI Processor, LG’s Latest QNED TVs Elevate the Home
      Entertainment Experience With Lifelike Picture Quality on Ultra-Large Screens
      SEOUL, Dec. 28, 2023 — LG Electronics (LG) announced the newest lineup of 2024 QNED and QNED Mini LED TVs, offering a wider selection of screen choices including ultra-large 98-inch with vibrant picture quality, advanced AI-powered processing technologies, extensive personalization features and sophisticated design.
      Evolving further, LG 2024 QNED TVs have developed significantly more intelligence with the α8 AI Processor, improving upon its predecessor with a 1.3-fold increase in AI performance, a 2.3-fold enhancement in graphic performance and a processing speed that is 1.6 times faster.
      Leveraging cutting-edge technology for a more refined visual representation, AI Picture Pro offers the ultimate picture quality based on deep learning. This versatile feature adeptly distinguishes faces, objects and backgrounds within a scene, enriching the texture and fine details to present images with unparalleled realism. Dynamic Tone Mapping Pro splits the picture into blocks and analyzes each in real-time to detect the darkest and brightest areas, elevating the details with precise HDR optimization to deliver three-dimensional image quality. With Personalized Picture Wizard, users can effortlessly customize the image quality by simply selecting a few preferred images from a given selection that are intelligently set up through deep learning.
      In addition to vibrant picture quality, AI Sound Pro captivates viewers with the audio excellence of virtual 9.1.2 surround sound from the TVs’ built-in speakers. For a unified audio system, WOW Orchestra seamlessly integrates the LG Sound Bar and the TV’s speakers, resulting in a mesmerizing 3D sound experience.
      Featuring LG’s Quantum Dot and NanoCell color technologies, the company’s latest QNED TVs deliver crisp and vivid picture quality for hyper-realistic viewing. With enhanced color reproduction, the authentic colors of QNED TVs heighten the visual depth for a more immersive and three-dimensional home entertainment experience.
      Achieving realistic contrast, LG QNED Mini LED TVs utilize Precision Dimming technology to improve gradations and accurate backlight control, and LG QNED TVs feature local dimming technology for vivid contrast and exceptional brightness.
      The LG QNED Mini LED TV QNED90 model features Million Grey Scale that differentiates between shades of gray and represents gradation with a 20-bit accuracy, providing immensely vibrant contrast.
      Boasting a sleek and sophisticated design with a slim profile of only 29mm, LG 2024 QNED TVs, including the QNED85 and QNED80 models, blend into any space and add a premium touch to the household. The TVs can also be mounted on the wall, providing greater flexibility for furniture and appliance arrangement.
      LG 2024 QNED TVs also elevate the home entertainment experience with versatile personalization and increased convenience. With the webOS Re:New program,* LG is offering an upgrade to the latest version of its webOS smart TV platform to give more smart TV owners the most up-to-date user experience for the next five years. This notable offer comes to LG QNED Mini LED 8K models launched in 2022 (QNED99 and QNED95 series) and will be extended to additional models in the QNED TV lineup worldwide in the future.
      By utilizing the latest LG webOS smart TV platform, users can create individual profiles to tailor the experience to their preferences. The TVs can differentiate between voices based on the user profiles and offer personalized recommendations by interpreting patterns from their comprehensive usage history.
      Furthermore, the main home UI screen of the newest version of webOS features Dynamic Q Card for fast, effortless access to its services, with customized organization into groups, such as Home Office, Home Hub, Sports and Games. To enjoy users’ favorite digital media, LG 2024 QNED TVs also support Apple AirPlay and Chromecast for enhanced convenience in connectivity and compatibility with mobile devices.
      Enhancing the user experience for individuals with diverse abilities, LG 2024 QNED TVs supplies an array of accessibility features including dedicated menu settings, sign language avatars, remote control tutorials, and guides for quick problem resolution.
      LG’s 2024 QNED TV lineup caters to customers’ diverse needs and preferences with a broad range of screen sizes, led by the ultra-large 98-inch blockbuster, a truly massive screen that will fully immerse viewers with its magnitude. The addition of the giant 98-inch model addresses the growing demand for larger TVs in the premium LCD TV market, and the extensive lineup also provides customers with multiple alternatives that will ideally suit any space, including 43, 50, 55, 65, 75 and 86-inch screens.
      “The LG 2024 LG QNED TV lineup takes the viewing experience to a whole new level with an advanced processor that enables outstanding audio-visual experiences across various screen sizes, while also providing a personalized user experience tailored to each individual’s unique lifestyle and preferences,” said Baik Seon-pill, head of the LG Home Entertainment Company’s Product Planning Division. “We remain committed to delivering an unparalleled customer experience, drawing upon our decade-long expertise with webOS.”
      CES 2024 visitors will have the opportunity to explore LG’s most recent innovations and technologies in home entertainment experiences at the company’s booth (#16008, Las Vegas Convention Center) from January 9-12. To keep up with all of LG’s exciting announcements at CES by following #LGCES2024 on social media.
      * Pop-up notifications offering a full upgrade without the need to select specific UX, UI or features are only sent to customers who have agreed to receive them. Please note that this upgrade does not cover the TV’s hardware performance, features or durability.
    • By Huig
      I have a UJ701V tv from 2017. I get a random disturbance of the sound and picture and then the tv reboots. I have already removed the back cover and everything looks fine. According the logfile i have to replace the mainboard but i think the problem will stay.
