I followed these steps to prepare my LG TV and it all worked fine:
However I cannot push IPK to tv or just list stuff:
I am getting this error when calling:
ares-device-info --device tv2
outputs:
ares-device-info ERR! [syscall failure]: read ENOTCONN
Any ideas?
I can ping the TV just fine and getting the key from the TV also worked but connection fail...
I am using macOS 12.16 and the TV is using webOS 4.9...
I also tried different node versions (v8.17.0 and v17.3.0)
Any ideas?
  • 2 months later...
44 minutes ago, fsmorygo said:
I have the same problem. Have you found a solution?
I could not make it work from macOs so I ended up doing it from a virtual Ubuntu (64 Bit) in Parallels Desktop... I am sure it will work with any other VM like VirtualBox as well.
  • 3 weeks later...
Posted (edited)
Yes, indeed, everything works stably on VirtualBox. I checked the operation of the machine itself and tested this software. I was using the latest version of VirtualBox at the time.
Edited by Alex
removed link
    • By Marko00
      only with cancel button.
      How to fix it?
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By Muser
    • By geoffHome
      Reset our router (turn off then turned on again  and waited) but now no networks are even found to attempt to connect to.
      Any suggestions what my next step should be?  This has happened suddenly.  Thanks
