i have created an Alexa routine for my LG C2 Oled 55 inch TV which will play Youtube video at the end but somehow alexa is manage to do that but without audio, the video plays well but audio doesnt even if the TV is not on Mute... I had tried it many a times increasing decreasing volume but it does not work.
but when i say alexa again while the video is playing (without audio) then hit back button to close alexa prompt then suddenly the audio starts playing... so i suspect it has to do something with audio takeover by alexa, i dont know for sure plz suggest
  • 1 month later...
I have the same problem, when it's on OPEN TV and I say ALEXA OPEN YOUTUBE, it opens but the videos don't come out with sound and if I go back to any other APP (NETFLIX/PRIME/TV/HDMI) the sound doesn't work anymore, I I have to unplug it to get the sound back. Firmware bug? Did you manage to fix it?
  • 1 month later...
I have a similar problem. Turning off the tv at night using the tv sleep settings is very cumbersome to access, so I set up a routine using the Alexa app on my iPhone to turn off the tv 30 minutes after I tell Alexa I am going to sleep. The next time the tv is turned on it has no sound. The only way to fix it is to unplug the tv, then plug it back in.
1 hour ago, DonaldG said:
Eu tenho um problema similar. Desligar a tv à noite usando as configurações de suspensão da tv é muito complicado de acessar, então configurei uma rotina usando o aplicativo Alexa no meu iPhone para desligar a tv 30 minutos depois de dizer à Alexa que vou dormir. Na próxima vez que a TV for ligada, ela não terá som. A única maneira de consertar é desconectar a TV e conectá-la novamente.
Open ticket in LG, I did that and they said they passed it on to technical support, who knows if more people do it they'll solve it with a firmware.
One thing I noticed if you turn on the TV with voice command, this problem tends to decrease, say turn on the TV, then volume 15 (example) doing this, it stopped being silent for a while.
  • 3 weeks later...
If your LG TV keeps going to Alexa, there could be several reasons for this issue. Here are some potential solutions:
  • Check your TV's settings: Make sure that the TV is not set up to automatically launch Alexa when it turns on. You can usually find this setting in the TV's settings menu under "Alexa" or "Voice Control." Disable this feature and see if it resolves the issue.
  • Disable Alexa on your TV: If you don't use Alexa on your TV, consider disabling the feature altogether. You can usually do this in the TV's settings menu under "Alexa" or "Voice Control."
If the issue persists, then this might help you -
    • By akhil7j
      At Frieze London 2024, LG OLED and Akomfrah Bring Art and Technology
      Together to Inspire Audiences With a Thought-Provoking Film Installation
      SEOUL, Oct. 11, 2024 — LG Electronics (LG) has once again partnered with the widely respected artist and filmmaker, Sir John Akomfrah, for Frieze London 2024. This collaboration follows LG’s recent support of Akomfrah’s British Pavilion at the 60th International Art Exhibition at La Biennale di Venezia 2024. At Frieze London 2024, LG OLED has invited Akomfrah – an artist and filmmaker known for investigating themes such as memory, post-colonialism, temporality and aesthetics – to present a new video installation at the fair.
      Becoming Wind (2023) is a five-channel video installation that focuses on the intersection of social and environmental issues, looking specifically at the experience of non-binary and trans actors and activists in the context of the climate crisis. A profound meditation on identity formation is framed by an allegorical representation of the Garden of Eden and its disappearance; a montage of footage evoking the abundant richness of past biodiversity is interrupted by glimpses of blazing wildfires, scenes of racial discrimination and a fragmented text, underscoring responsibilities to confront multiple and intersecting crises.
      Powered by the compelling fusion of art and technology, multiple ultra-large LG OLED displays bring Akomfrah’s artistic narratives to life with stunning picture quality on an incredible scale. Notably, LG OLED’s self-lit nature reveals the full, vivid expression of the colors, enriching the depth and realism of the artwork’s multi-sensory elements for a truly immersive experience.
      LG’s commitment to making LG OLED a more sustainable choice closely aligns with Akomfrah’s drive to address climate change, human communities and the plight of migrant diasporas globally. LG OLED TVs incorporate fewer components than LCD TVs due to the absence of a backlight, which results in the 65-inch OLED TV using 60 percent less plastic compared to an LCD TV of the same size. Weighing in at about 20 percent less than an LCD TV of the same screen size, OLED screens also contribute to the reduction of CO2 emissions during transit. In addition, recycled plastic accounts for approximately 20 percent of the plastic used in the manufacturing of all LG TVs, including OLED models. These efforts have culminated in LG OLED TVs receiving environmental product certifications from the UK’s Carbon Trust and Switzerland’s SGS for four consecutive years, underscoring the company’s commitment to sustainability.*
      “I’m truly delighted to be able to bring my artistic vision to life with LG OLED,” said Akomfrah. “Becoming Wind aims to draw viewers into a deep state of contemplation about the intrinsic relationship between nature, humanity and technology through the interplay between sound and visuals. LG OLED’s advanced audiovisual capabilities and technological advancements enhance the sensory elements of the art, seamlessly integrating image, sound and emotion to take audiences on a visually compelling and intellectually stimulating journey.”
      “We are pleased to continue our collaboration with renowned artist Sir John Akomfrah to highlight how LG OLED captivates audiences by enhancing the depth of his thought-provoking artwork,” said Kate Oh, vice president of the Brand Communication Division at LG Home Entertainment Company. “LG OLED remains committed to supporting both artists and audiences who embrace our passion for innovation and positive change. We will continue to empower artists who seek to inspire the world through the intersection of art and technology.
      Visitors to Frieze London 2024 can experience Akomfrah’s artwork Becoming Wind from October 9 to 13 at The Regent’s Park. Visit the
      link hidden, please login to view to step into a world of artistic brilliance and explore captivating collaborations with LG OLED ART. # # #
      * Carbon Trust: Carbon Footprint Reducing certifications (2024 LG OLED evo G4 77”/65”/55”)
      Carbon Footprint Measured certifications (2024 LG OLED evo G4 97”/83”, C4)
      SGS: Environmentally Evaluated certifications (2024 LG OLED evo G4/C4/B4)
    • Guest
      By Guest
      Things that I've tried:
    • By Speedemon
      I have a UK6300 LG TV. It has always worked faultlessly. However it now will not show the pointer unless I restart it and then it only there of only for 20 seconds and then it is gone. The LAN cable notification constantly disconnects and reconnects. The Web Browser no longer opens on my selected page. The Software version is the latest and when I tried to manually update the software in case the auto update got corrupted it will not recognize the USB drive as having the software on it. The software browser version is 05.50.15.
      Any ideas what to do. I have two other LG TV's and all work perfectly.
    • By Trevin
