HP Email: Hard to fulfill Touchpad orders
I just received this email from HP:
  Hewlett-Packard
Dear Customer,
Thank you for your interest in the HP TouchPad and webOS. The overwhelming demand for this product in recent days has made it difficult to fulfill your request at the present time, and we are working to make more available as soon as possible. While we do not yet have specific details, we know it will be at least a few weeks before we have a limited quantity available again. We will keep you informed as we have more specifics that we can communicate, and we encourage you to join the conversation here for the latest information.
In light of this and other recent HP news, we want you to know that we remain committed to you. We will continue to honor our warranties now and in the future. We will continue delivering products that make a difference in your life and we will continue to provide the best possible service to you every day.
We are grateful for your patience and loyalty and to show our gratitude, we are offering you an exclusive one-time opportunity to save an additional amount on all of our products, valid through the end of the day tomorrow, Wednesday, August 31, 2011. You'll save 25% off all printers, ink, HP accessories, and PCs starting at or above $599. To take advantage of this offer, use your unique coupon code at checkout, and for more information on the details of this offer, please look at the bottom of this email.
Sincerely,
hpdirect.com
Valid for HP Direct (hpdirect.com) internet and call center purchases only. Coupon valid while supplies last. Any unused portion will be forfeited. Each coupon code is limited to one usage per customer; one coupon code per checkout. Offer void where prohibited, taxed or restricted by law. Non-transferable. Not valid retroactively on previously purchased items. Not valid for any resale activity as defined by HP Direct. Coupons may not be used to purchase gift cards. May not be permitted with certain bundle offers. Products and support acquired by Customer under these Terms are solely for Customer's personal use and not for immediate resale or sub-licensing. Valid on: all printers, ink, toner, paper, HP branded accessories and all the following PCs: g7-1150us, dv6-6126nr, HP Pavilion dv6-3230us, dm4-2050us, dv6-6140us, dm4-2070us, HP Pavilion dv6-3240us, HP Pavilion dv7-4277nr, HP Pavilion dv6-3250us, dv6-6150us, dv7-6175us, HP Pavilion dv6-6091nr NB PC, dv6-6170us, dv7-6195us, dv6-6190us, p7-1020, AiO , s5-1060, HPE h8-1010, HPE h8-1020, TS 610-1130f, HPE h8-1032, TS 610-1030f, TS 610-1150f, HPE h8-1041, TS 610-1190f, G7T, DV4T, DM4T, DM4X, DV6T, DV7T, DV6T SELECT EDITION, DV6T QUAD, DV7T QUAD, p7qe, s5xt, h8m, h8t, h8z, h8xt, h8qe, h8 select edition, Omni 100t, Omni 200t, Omni 200xt, Omni 200 Quad, 310z, 610z, 610t, 610xt, 610 Quad, Envy 14, Envy 14 Beats, Envy 17, Envy 17 3D. Not valid on: Friends and Family program, HP Academy and Employee purchase programs, HP Employee Purchase Program, Refurbished products. Not valid on purchases from HP download store (hp.digitalriver.com). Offer not combinable with Instant Rebates. For complete coupon conditions, see "Coupon Information" in the "Customer Service" section at
You're receiving this communication because you have expressed interest in receiving notifications about HP TouchPad. To unsubscribe, please reply to this email.
We try hard to make sure all of the information in our email is correct, but sometimes mistakes do happen. HP TouchPad Notifications is not responsible for typographical errors.
10955 Tantau Avenue, MS4330, Cupertino, CA 95014
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By Laurence
      I have an LG65UR80006LJ and when I plug my portable hard drive in to one of the USB ports, it lights up and sometimes the thumbnail folder gets added by the TV (I can see it when I plug the drive back into my PC) and twice now it has operated as expected and it appears as a device on the media app.
      But it has only worked correctly twice and now doesn't find the drive at all, despite me having reformatted it and only add one file to the root directory (the first page if this makes sense; not buried in sub folders.)
      Before I box the TV back up and send it back, is there anything else I need/can do as my 12 year old Philips smart tv has no problems what so ever finding the drive and playing the media on it?
      Thanks in advance for your help.
      Laurence
    • By williamsats
      Hi everyone!!!
      Lately I have a problem with my 40UH630V (OS Ver. 05.70.30). It takes too long for a hard drive or a USB stick to get it ready to play video files. That means that I have to plug in my hard drive or USB stick and wait for at least 4-5 minutes before I can play the video files, no matter what type/format they are. Sometimes I have to unplug and re-plug my drive so to read it.
      Here I must point that both USB ports are clean with no dust or any corrosion, USB cables are new and fully functional and all hard drives and USB sticks are working perfectly on my 32LQ63806LC.
      Also in some cases i get a message on TV for a format compatibility but I don't think this is the case, since if I wait 4-5 minutes (sometimes a bit more) then it reads them normally.
      Any ideas?
    • By Scotty
      Hello, LGLovers
      I'm looking for pure clairty here, so I have a 43lm6300pla and it's my wish to plug in an external hard drive to record freeview. Now I was under the impression you could get a 2tb hard drive, plug in and go but it seems a lot more difficult than that and I don't want to spend a fair amount of money for it to be useless.
      The information on the TV regarding the criteria is a bit contradicting. Basically yes use a external hard drive but don't use an external hard drive. Use a drive that's powered by a cable.
      The Seagate expansion plus 2tb sounds utter perfect but I'm too apprehensive to purchase it.
      If some one can shed some light on this I'd be almighty grateful
      S
