LG UH6500 Multiview picture settings
By DW1
By Cody94549
By Low Grade
many thanks in advance😃
By Željko2
I own a TV LG oled65c31la.aeu. I am interested in whether it is planned in the next firmware updates to return to multiview the
option of displaying two live channels (antenna dvt2), as it was earlier in webos 2.
Previously, a buffer was created in which terrestrial channels were saved, from where they were marked for display.
By Željko2
Hello everyone.
Thank you.
Ash0837
Any way to chang picture settings in multiview? I'm able to connect 2 hdmi devices but I'm unable to change picture settings while in multiview. It's locked on Vivid mode. Any way to change to game mode? Both hdmi inputs are on game mode, but multiview is on vivid.
