Setting a default input or app when turned on?
By mean2
By OhmorrowSouthWales
By woof
I have a couple of LG OLEDs in shared spaces, with external speakers, one via optical and the other via analog jack (confusingly named headphones). Whenever bluetooth headphones are used and then disconnected, the TV reverts to "internal" terrible audio. For non-technical people this is permanent. Do I have to train everyone to select the device from the long list or can I set a default?
By starwoodtech
By starwoodtech
I followed the instructions to set the default input on my TV, but every time I cold start it, it simply goes to the screen where there is a list of apps. I try to repeatedly go to the HOME app to try to set it again, even though it already shows HDMI 4 as the start up input, but it simpy goes to the default screen where my apps are listed.
Does anyone know what it would take to set this?
montanabeefy1
I have an LG TV using the magic remote. I discovered that it allowed for either the LG tv or Sling TV to be able to be set as an input so I got sling tv. I am now wondering if there is a way to set that when you power on the tv, it will automatically go to the sling tv input (or app)?
