hbbtv installed version
I aIl
I cannot receive Rai1 4k fifa game,
The message sayd It Is supported only from version 2.0.1.
How can I check my installed version?
I have received Hbbtv Channel until a few days ago
Let me know
Fausto
    • By Michael Hirons
    • By NaveenKumar
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
    • By Steve D B
    • By Ali Zia
