No audio out from smart apps, OTA antenna
Just purchased this and the set up is driving me nuts. I have a Sony reciever that I use for my audio out as well as HDMI device switching. The output of the reciever is going to HDMI 1. The TV audio out is set to HDMI (ARC) device.  When watching devices directly connected to the reciever (cable box, roku, DVD, Tivo), audio out is fine. If I try switching to the smart menu or the antenna, there is no audio going from the TV back to the reciever. I also have a Roku I can use for streaming, but not for OTA.  Should I just route everything directly into the TV, and use the optical out to get sound to the reciever? Also since setting up the TV and remote there is strange interaction btween the TV and the reciever. I noticed that my cable box, dvd, and roku all show up devices attached to HDMI 1, and clicking on that device will change the input on the reciever, but I have no control over the reciever from the LG remote, volume and muting buttons have no effect. Also there soesn't seem to be anyway to control my Fios cable box, a Motorola HD QIp 7100-1. I have the IR blaster sitting right next to it
Since I don’t know which Webos tv you have or Sony receiver, I can only recommend you make sure you plug the HDMI cable into the arc/earc port of the tv to get OTA sound from the tv to the receiver. Also your receiver must have arc capability with CEC and arc turned on.
    • By thewookiewon
    • By DW1
    • By Will M
