YouTube app destroyed
By David Joseph
By Владимир Морозов
By Lee Magee
By JonoW
By Stephen Pritchard
For some reason the scroll right and left arrows have disappeared from the youtube app when using my mouse.
I've tried installing the app again but no luck.
Any ideas?
