- 1
Youtube App Hanging up/Freezing up..
By Lee Magee
By Will M
By David Joseph
By Владимир Морозов
By JonoW
Sunny
Youtube App is showing the list of videos but some times not opening the video and the screen is blank. I tried reinstalling the app and it worked for some time and faced the same issue. I also tried clearing the cache as well, still the issue persists. Can any one had the solution for it?
