Filmrise app internet error
By Mandx
By Marko00
only with cancel button.
How to fix it?
By leader6234
Hey guys !!!
Thanks in advance !!!
By Muser
Douglas M miller
Hey folks,
I recently downloaded the Filmrise App from the content store. My issue is that no matter what I try to watch a box appears on the screen saying there is an internet loss/disconnection. The message box is clearly from the app and not from the LG TV operating system. To add insult to injury, even with this "error" the selection is still streaming crystal clear in the background behind the box.
Any thoughts?
3 answers to this question
