Red Cursor of Magic Control Stopped Working on both TVs
By Roy Brown
By RJ Fischer
By Rex G
By Regis Wheeler
By DavidSr
Martin Janus
Hi, strange thing happened, I have two different LG TV with webOS and each has its own magic remote control. I just found that red cursor disappeared on both TVs and nothing helped: new batteries, unplugging from the socket, re-pairing. I tried to re-pair one of the tv and it did not paired anymore, all buttons work except cursor. When I click the middle button (pointer) it always says trying to register and then this control is not supported by this TV. I have both TVs around 2 years. Looks like a firmware problem but both TVs has different number since they are different types, both has auto update on and both are up to date. One is 65" LG OLED65GX (firmware 4.40.20), the other one is 77" LG OLED77W9PLA (firmware 5.30.11). Any idea?
