Solved I found it. Hope this helps other people like me.
Press Home on remote
click Home Dashboard on bottom left
top right clicks 3 dots
click Edit Inputs then click the icon left of your HDMI and set it the PC.
  • 1 year later...
    • By mean2
    • By OhmorrowSouthWales
    • By starwoodtech
      I followed the instructions to set the default input on my TV, but every time I cold start it, it simply goes to the screen where there is a list of apps. I try to repeatedly go to the HOME app to try to set it again, even though it already shows HDMI 4 as the start up input, but it simpy goes to the default screen where my apps are listed.
      Does anyone know what it would take to set this?
    • By Ozzie T
      We have a 65UM7300AUE with software version 05.40.10. We have a Google TV dongle plugged into the HDMI 1 port and that is the input we use most of the time. Until recently every time we would turn the TV on it would default to HDMI 1 and the Google TV home screen would be the first thing we’d see. Life was good. Several weeks ago that changed and now the LG OS (I assume) home screen is the first thing we see. Then we have to use the LG remote to select HDMI 1 each time. We never used to have to do this or use the LG remote at all. Kind of annoying. We think we have HDMI 1 chosen as our default input but it doesn’t seem to matter. Any ideas on how we get things back to the way they used to be with the TV defaulting to HDMI 1 automatically?
    • By Alfaro
      I have a problem with my LG 43NANO756PR: if an app is paused (for example a youtube video or music track is put in pause), after about two minutes the TV goes back to the TV antenna input. Very unpleasant if you are on the phone and need a quiet environment. Same thing if I mute the audio: after about 2 minutes the volume resumes as before.
      Any way to sort this issue?
