LG UK6190 internet problem.
My LG (75" UK6190) internet connection, connects and disconnects all the time. Using either wired or Wi-Fi. Usually I will have to turn off the tv and turn it back on to reconnect to the internet. I have the issues constantly with You-Tube. the TV worked fine for 2-3 years then went south. My fiber optic internet has been checked out. No problems with it. And runs about 500 up and down. My Nighthawk AX5400 router has no problems. I have taken the router out of the loop and wired it directly to the internet and the problem doesn't change. My Android OS tv's work fine with no issues. I'm thinking a LG update issue possibly? Since it worked fine for a long time and all of a sudden didn't. I don't want to replace the TV. But after a year or so of this issue I'm getting there. Anyone else had this problem? Any idea's?
Thanks, Bill L
    • By NickL
      Br,
      Nick
    • By Venkata
      Hello Team,
    • By Mandx
    • By PVD
    • By hollean
