Can't find the correct satellite on my tv.
By OhmorrowSouthWales
By Michael Hirons
Can anyone advise me whether this tuner is "generic" or freesat? and i would like advise on using it with a Sky+HD satellite dish.. any advice/help appreciated as im cancelling sky contract soon Michael
By Tony Levy
I live in Spain hence the two systems. When I press the home button on the remote the list is at the bottom and displayed are LG Content Store HDMI3, LiveTV Freesat etc but no button with the aerial option, so the only way I can switch is to go into the main settings menu select Programme Tuning and switch the programme mode from Satellite to Antenna.
By leader6234
Hey guys !!!
Thanks in advance !!!
By JayDee
I have spent countless hours trying to figure out which remote is compatible with my 27 inch LG television. I can find the TV on LG's website (after intensively searching each time), but when I search the Magic Remotes for compatibility, I've had no luck in anything matching the two.
TV model is 27LQ625S-PU, purchased from Best Buy in America. I'm running 7.3.1-38 for webOS TV version. Trying to purchase one elsewhere online also seems to not have anything resembling my TV make/model.
I don't know what else to do in order to find a remote that works, and I don't want to spend the money trying ten remotes until finding one that does. Am I missing something through the site where I should be searching? Do all remotes work based on webOS version? I'd really love to upgrade this mostly useless remote. I don't use it much right now because I don't like typing through the on-screen keyboard and the remote that came with the TV isn't as easy to use as a universal (I think some of the buttons are in oddly located places). I tend to use external smart devices because the (dumb) remote/webOS don't seem to pair together very well.
I appreciate any help you guys are able to offer, and apologize if this seems like a foolish question.
Greg 5
Hi all,
I am living in Ireland and have my satellite dish tuned into eutelsat 28a. This works fine on my free to air box but I can't seem to find this satellite option on either of my LG tvs. Does anyone know how to add this Satellite to my tv? Thanks in advance.
