Log in error
By Marko00
only with cancel button.
How to fix it?
By leader6234
Hey guys !!!
Thanks in advance !!!
By Muser
By geoffHome
Reset our router (turn off then turned on again and waited) but now no networks are even found to attempt to connect to.
Any suggestions what my next step should be? This has happened suddenly. Thanks
hans peter
I get this message when trying to log in too the CMore-site from my smart-TV LG 32LM6300PLA with the programversion 05.30.11:
An error occured, please make shure your browser is updated to the latest version and try again. We support recent versions of Firefox, Chrome, Safari and Edge. If you still experience problems accessing the site using a recent browser please contact support for TV & Play.
Who is We and who is support for TV & Play?
Has anyone an idea of what I have to do? Either with the TV itself, its webOS-browser or perhaps with the site CMore? Or can lead me in the right direction?
/hans peter
