TV Resolution Question
By dolbnya
By Fricassee
By Wondering
By styopa
I moments ago was watching the linked youtube.
Highest resolution on my desktop 1080p
Highest resolution offered on my LG CX (whether wired or wireless) 360p.
Desktop and LG tv are about 8' apart. Using same wifi/router (connected to 1gig/1gig fiber). LG tv fully updated.
Any idea why LG youtube app is so terrible?
Thanks for any advice.
By Girevik
Hello all,
I recently got a soundbar for my LG TV and have it connected with HDMI ARC on HDMI 2 I do my TV watching with a Firestick. I have this weird issue where if I switch apps on my Firestick using one of the buttons that go to an app, or (sometimes) using voice commands, the switches to the HDMI 2 input. If I choose the app from the menu, it works fine.
I have no clue why how I start an app makes a difference, but is there a way to set the TV to ignore HDMI when it comes to automatically switching inputs? I looked through the settings and thought I figured it out when I turned off instant game response on HDMI 2, but the switch is still happening.
BUB
2 TVs, one OLED77CXPUA and the other just installed OLED65C2PUA. 77’ shows a program in 2160p while the 65’ shows the same program only in 1080p. Anyone know why ? Thank you.
