Dobrý den,
Při sledování Smart TV LG s android boxemTesla se mi často vypíná obraz (problikne) a v rohu se objeví HDR. Nevím si rady v TV to nejde zakázat tak už opravdu nevím?? Kabel?? Mohl by mi prosim někdo dát někdo poradit co s tím?? Děkuji.
    • By coyote
      I'm surprised by how few Settings there are.  Is there an Android Settings App?
    • By Ayon Mondal
      Whenever I'm trying to run hotstar on my TV it is showing that NETWORK CONNECTION NOT STABLE TRY AGAIN.  Please solve the issue as soon as possible and let me know how to fix it.  This is the serial number of my TV :- 64387205122152TRFLJL
    • By SGray
    • By Deepak Suresh
      SunNXT app looks different and old in WebOS and Android TV app is great now and latest.
    • By Francis torres
      Greetings good how can I install android applications on my tv and I need help with the soware for Latin America of my 49UK6400PLF
