    • By Information Technology
      Hello Everyone,
      I am new here. I have LG Smart TV (50UN7340PVC) and would like to connect with Logitech Conference USB camera (BCC950). Does anyone have idea whether it support or no? When I connect, the message pop up that HID device connected. After that I can't find any option for the camera. Please advise. Thank you
      Key Specifications:
    • By Xuancong Wang
      Dear LG TV developers,
      I am glad to see that LG Smart TV has a built-in web browser and LG API supports "openBrowserAt" so that my smart home controller can open a web page on the TV. However, nowadays, we also have ms-teams online meeting that is accessible through web browser which the LG TV supports. However, this requires the browser to have a microphone to record audio and to have a webcam for video recording. Also, certain smart-home systems also need built-in microphone to record voice commands so that no additional standalone unit is required next to the TV.
      Unfortunately, LG Smart TV (I have OLED48A1PTA) does not have microphone neither does it support USB mic/webcam. So I am writing this post to suggest that future middle/higher-end LG Smart TV can be equipped with these. Moreover, it might be possible for TV firmware update to add the support of USB webcam/microphone so that they can be used in web browsers for web-based online meeting.
      Thank you very much for your consideration!
      Best regards,
      Xuancong
    • By William Quay
      We have a new 32” LG tv. The picture is great. Sound is great. Controls are confusing to us.
      when using DVDs the resolution seems fine. But when cable tv is on the image overflows the screen, cutting off parts of the picture.
      we can’t figure out how to fix. Probably simple, but we can’t find it.
      Help?
