App has not been installed. try again error
I am facing this issue after updating to the latest version of firmware. On my Wifi, I am not able to install/ update any app. Error is coming as written in the title of this post. But when I am using mobile hotspot everythings fine. I have tried all options resetting my router to factory reset, resetting TV, dns setting change to 8.8.8.8. but nothing is working for me for my Wifi.
My tv model is LGUP7500PTZ pls help
    • By Michael Hirons
    • By Calvinder
      One suggestion was to go to Settings>all settings>general>AI Service>Voice recognition service and change to LG ThinQ.
      But the  Voice recognition service tab is gone. There is only voice recognition settings tab
      I would rather not have to reset to factory settings unless there is a way to save / export my current seating's
      Any suggestions
    • By Marko00
      only with cancel button.
      How to fix it?
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By Muser
