LG CX youtube app offering only terrible resolution
I moments ago was watching the linked youtube.
Highest resolution on my desktop 1080p
Highest resolution offered on my LG CX (whether wired or wireless) 360p.
Desktop and LG tv are about 8' apart.  Using same wifi/router (connected to 1gig/1gig fiber).   LG tv fully updated.
Any idea why LG youtube app is so terrible?
Thanks for any advice.
    • By Lee Magee
    • By Will M
    • By David Joseph
    • By Владимир Морозов
    • By JonoW
