PreCentral: Monday Brief: HTC One V, Side-loading, Woz gets a Lumia 900, Instagram ownership and Pivot lives on!
By hjetschko
Hi, I have a feature request for the sound out setting. I often connect my Bluetooth headphones to the TV. We don't use the internal speaker of the TV, we use the optical sound out setting whenever I don't use Bluetooth. It would make our lives a lot easier if the TV can remember the last sound out setting before connecting to Bluetooth and default back to this setting when the Bluetooth device gets disconnected. At the moment, each time I disconnect the headphones I have to go back into settings and change the sound out setting from internal speaker to optical again.
Thanks and regards
Hubert
By Nishanth Noble
Hi!
The TV model number is UH850V and the firmware version is 05.30.30. I often get the WiFi disconnected automatically. I have tried manual mode too but it’s the same. Once disconnected it does not identify any WiFi signal. I have to switch off and switch on the Tv for it to identify a WiFi.
I would like to know if this can be fixed by software update or is this an hardware issue.
please help
By Nishanth Noble
Hi!
Recently I have noticed that the Wi-Fi gets disconnected automatically without any prompt. While searching manually, no Wi-Fi signals are listed. But once the TV is switched off and turned on again the Wi-Fi gets connected. But after few hour gets disconnected again.
I would like to know if this is a technical issue and how to resolve this issue for good.
By Lijo
I have been using webos for my signange where I render my advertisement and configured live news feeds. I have configured as follows
Live National news - > Advertisements->International news->Advertisments..etc.. This is how i configured ,but noticed that application gets hung and wanted to know
1)Is webos not designed be used for such a heavy applications/rendering?
2) Malayalam fonts are not rendered properly where as it is working fine in Android.
Can somebody throw some light on this ? Appreciate if someone from LG can respond as well
Rgds
Lijo
By Henry Alonso
Its been a long while, i haven't got luck with LEDs TV online. Thou it's panick on offline shopping, but what are some cheesy places to get it.
[Thread]
