Amazon Prime Video stopped working after WebOS update to 04.40.70
By mean2
By OliverRC
By Ajothen
By Roy Brown
By atcronin
- 1,204 views
- 2,941 views
- 9 answers
- 4,658 views
- 1 reply
- 6,241 views
Nitin Chopra
Hi Team,
After update of LG WebOS to 04.40.70, Amazon Prime Video app on my LG Smart TV stopped working. It started giving error :
Internet Connectivity Problem
There is an internet connection problem. Check the device's internet settings, data cables, or try to resetting your router. Also, turning your device off, and then back on might fix the problem. For further assistance, please contact Amazon customer service at www.amazon.com/videohelp
The internet/wifi connection is fine and all the other apps are working without any issue on the LG smart TV.
I have even tried uninstalling and reinstalling the Prime video app, but that didn't help.
Has anyone faced this issue ? Is there a solution available for this issue.
Thanks & Regards,
Nitin
6 answers to this question
