auto detect bluetooth headset does not work
By Venkata
Hello Team,
By Horniak
By CJ Catalano
By JRay
dracula1001
I own a 55 inch LG WEBOS TV SM8100PVA and I am connecting my SONY WH-1000XM3 bluetooth head set to the TV, it used to auto connect as soon as I power on the headphones, but now it only connecting manually, I have tried to reconnect them (forget and connect again) and the auto detect isturned on, I cannot auto connect them
meaning every time I have to connect them, but only manually, it started happening after I connected them once to my phone and than I unpaired them from my phone,
Can anyone assist :)?
thank you
