New 2022 LG smart TV can’t move HD channels in UK to 1 to 5 from 101 to 105
Hi just got a new QNED LG to replace 2021 Nano tv
the problem is I can’t move my HD channels down to  channels 1 to5.
the program manager does not have the function to move channels like my old Nano tv which is only a year older.
is there anyway I can get around this strange function?
I am tuning the tv from the outdoor Arial function if that helps with an answer.
    • By Will M
    • By Lesbo
    • By Rex G
    • By Mogens
      Kind regards
      Mogens
