By
atcronin
JohnoFon
I am using an LM6300PLA, WebOS version 05.30.11
When I try to record a series from the Live TV - using input the satellite connection - the first episode records correctly, but subsequent episodes all stop after 3 minutes.
What am I doing wrong?
Further annoyances are that I can't just set it to record all episodes of a particular show (the way my HUMAX Freesat does), but only 'repeat recording on specified days' with no end-date.
Does this mean that the recorder has no access to the Electronic Programme Guide, but just sets a time and duration? If the broadcaster reschedules the programme does the recorder just pick up the replacement?
