Maximum permissible size for LG installable files
By mahdi alborzi
I need to update this TV
Model : 55SJ850V-TA
Serial number : 707CGKWMJ215
ESN : LGTV20171=11001816919
VSN : 1F580793
Widevine: LGTV17CLGE002389488
By mahdialborzi
از درگاه وای فای بروزرسانی نمیشود پس نساز به فایل برای بروزرسانی با فلش مموری کارت دارم.
لطفا کمکم کن ید
By Jimout
I am getting a "cannot download files" when I try and download a FirePro file.
I was able to download before.
Is there a way around or fix.
By Jean Fiorin
Good Morning, There is a recommended minimum distance between the TV and the viewer. I bought an LG OLED C155 last month and it is uncomfortable from a distance. It was my mistake. I bought it without worrying about visual comfort. Is it possible to reduce the screen's usable area to simulate a screen size TV of 48 inches or less, accepting the black borders that would be created? It would be something similar to a custom aspect ratio. The idea would be to be able to simulate a smaller screen size than the purchased equipment. other-bigger->65->55->48->other-less -
By tee4
Hello
I am trying to develop one app for LG smart tv, and I have one LG smart TV at home.
I am facing one issue with the app icon on the home page.
It is smaller in size than the size of the icon space , even I have set it to 1920x 1080 or 1280x1280.
How much bigger size I take, it still leave some space around the actual image of the icon and shows a black space around the icon.
Siva Shankar reddy
Hi, We need know the information about maximum file size limit for installable files , and the LG play store policies, Need this info really help us on application development process for LG ( web-OS ). As per the Android play store we know, it allow's the applications based on the availability of internal Storage on the specific device. Please Let Us help here to under Stand the LG Play Store behavior for the application development process
