Cannot pause using pause button on my headset
I've recently bought a 65QNED913PA TV (currently with latest official software) and I connected my Bluetooth headset to it - Jabra Elite 85t. Whenever I try to use pause button on my headset (while watching YouTube, Netflix, Disney,...) sound gets muted, but video does not pause. When I push the button again sound comes back and nothing else happens. Should my TV support pausing video from my headset or this does not work by default?
Regards
Maciej
SUPPORT MENU
    • By David Daul
    • By hollean
    • By Dennis Radliff
    • By Joe C
      Since the Web OS update last week, the line on the Home Screen with all my apps has changed.  Now Apps is the first one in the line.  I do not want it there, but cannot move it.  If I go to the end where it shows Edit Apps, I can click on any app to move it or delete it.  But, the Apps icon is grayed out and cannot be moved.  My neighbor has the exact same model I do -- LG OLED 653PUA -- and it is not like that on his tv.  He can move the App icon anywhere he wants.  This is very annoying as it defaults to the Apps icon when I click on Home and then I need to click to get to YouTube TV, which until the update was always first in the line.
    • By JamieG
