screen clock
By pingber
All of a sudden, the row of inputs showed up at the bottom of the home screen on my C1. I’ve tried every setting but can’t seem to get rid of them. I used to just call them up as needed (input button on remote) but now they’re there permanently. Any ideas?
By TVNerd95
Bought a new C4 OLED but i get black screens randomly when using internal streaming apps or just going back to the home menu. It seems as if WEBOS is crashing and i can only cut power and reboot when this happens...
Is it a software or panel issue
By victoranthony
Hey everyone,
I have had LG TV for just two years. Last weekend, when I turned it on, it showed a blank white screen but was still illuminated, with sound working. No LG logo or image appeared. I unplugged the TV and held the power button for 30 seconds while it was unplugged, and the screen issue fixed the issue for a week[url=https://whitescreen.vip/
].[/url]
However, the same white screen problem has now returned, and the power reset trick no longer works.
Should I contact a local TV repair technician or reach out to LG customer support first? Any advice?
By joe zx
I have LG oled 55b8pla, it is connected to the net, it has the latest update installed, when I start the web browser application and in the on-screen keyboard I start typing for example the URL of the web page, so instead of the number 1 it displays a number 2, instead of the number 2 a completely different character, etc. etc. etc.
I turned the TV on/off, turned the app on/off, unregistered the remote and registered it again. No effect so far.
Any advice, thanks.
By Low Grade
hi,
