- 1
How do I get my voice recognition to work again
By Horniak
By CJ Catalano
By JRay
By P.T.
I have a LG G3 Oled Tv 65 inch. I want to record Tv programs using the correct USB HDD . Could some one out there give me some specifics of a USB HDD that will work on my TV .
Peter
Calvinder
Any suggestions
8 answers to this question
