Echo from internal speak+Audio out (optical)
By Regis Wheeler
By ato53
I have a new C4 TV.
Thanks for the follow-up
By JohnoFon
By starwoodtech
By coltaz
maninblack2000
I have a 55" Tv and a LG soundbar, i have put the soundbar behind where I sit, basically so my TV doesnt have to be up so loud. Its connected with a optical cable. I changed the sound setting on the TV so the sound output is 'Internal speaker audio output (optical) This works perfectly for an hour or so but then it develops a faint echo effect? If i change the setting to just internal or one of the other settings, then change it back, its fine again for a while, but then the echo comes back? Anyone know why this is?
I have tried every setting i can find but it still happens?
