Bug in TV program guide info pop up?
Re. LG C2 TV, WebOS ver. 03.30.16
In the TV guide if you hover over a program selection (or it's (i) symbol) with the pointer the program's info dialog pops up.
The problem I have is that after 5 to 10 seconds, while the program selection remains, the info dialog reverts to the currently playing program. This is a real pain as I for one can't read all of the program info in that time.
If this is intentional is there somewhere I can configure the info display time or is this (as i suspect) a bug?
    • By JasonB
    • By northshields
    • By Peter_T
    • By wallyricks
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
