Hello all,
I have noticed a problem with Airplay on my LG TV.
I have disabled Apple Airplay from the Airplay settings but on my Apple devices (my iPhone, Macbook), when the TV is turned on, it is still detectable.
If I click on my TV from my iPhone, it is impossible to connect. However, the TV is always detectable, which is annoying.
To sum up, it's as if the detectability of Airplay and its status (active/inactive) are two separate things.
Ideally, if Airplay mode is disabled, the TV should not be detectable on Apple devices because it is confusing and bad from a user experience point of view.
Has anyone an idea how to fix this or how to escalade this issue?
Best regards,
Baris
PS: My television is the model OLED55CX6LA.AVS
    • By atcronin
    • By Pranay Mokida
    • By Cody94549
    • By Rayden79
      I'm having this problem with LG Oled 65c16LA with WebOs Version 03.40.85
      When I turn off the TV, it goes into standby mode.
      After 2 minutes the red standby LED turns off and it is no longer possible to turn the TV back on with the remote or with the power on button.
      It is then necessary to unplug the power supply, wait a few minutes and reconnect it.
      So the TV goes back to standby and you can turn it on again. In use everything works.
      Is it a software problem? How can I solve it?
      Thank you
    • By Seppel
      i am in the process of purchasing several LG digital signage displays and need some more information before i place
      my order.
      I need a function like kiosk mode to start a website in full screen mode on device startup.
      The device would be a LG 43UH5N-E installed is webOS.
      Is this posswible with the onboard functionallity of webOS or do i need a 3rd Party App ore something?
      There is no need for a pagerefresh or such things, only display of es simple Website.
      thx for help me out.
