Netflix app
By Nicola123
By svsrama
Sriram.
By cptl
Any thoughts?
By Sandtonman
Dolby Vision is 22.11.
By Apan Chakraborty
Netflix is not Working on my TV though it is in the Remote Button. After pressing that button, it is going to LG content store and it's showing 'Content is unavailable. This function is not available.'
Edgar Corona
I have a 55" smartv, i'm having problems with Netflix app, anyone knows why, i can't open de app, everything after and update send it by the tv..
