MX Player And Ullu Application
Hi Team
On 2/28/2023 at 10:57 PM, Nishant singh said:
Hi Team
If you want many apps like this ypu should heve bought an Android OS TV...
Why is it app requests are constantly given a “should have bought an android tv if you wanted this” reply or similar! Smart tvs normally have a good range of add on apps for various things including different media players! LG tvs are great but web is is poor compared to all others and is indirect need of improvement! Surely LG must be aware systems on other tv’s are have far superior app libraries for consumers to pick from?  Great visuals but terrible smarts!!
    • By Jack1151
    • By wallyricks
    • By MNHL
    • By Junaid Ahmed
    • By Ganesh R
      Hi LG Team,
      Regards,
      Ganesh R
