This improvement is related to external subtitles.
1. I can only see 7-8 external subtitles in the list, while the rest are not visible, although they are visible on the PC. It would be helpful if you could add a scroll bar and show the entire list of available subtitles instead of only the first 8 that are alphabetically sorted.
2. All listed subtitles are named numerically [1., 2., 3., 4., 5., 6., 7., 8.]. I request that the label for each specific language be shown instead, such as:
- Eng, Fra, Ger, Bos, Ita,...
or better yet:
- English, French, German, Bosnian, Italian, etc.
    • By mycop
      Greetings.
    • By bos2prov
    • By Pranay Mokida
    • By Cody94549
    • By MURAD
