Plex unusable on webos
Is it just me or is the plex app just unusable on webos.  When I try to select dvr items with the magic remote they just don’t play.  I am not sure if this is a plex issue or an lg webos issue.  Anyone know which it is?
9 answers to this question
Hi @Lgrump
I suppose it is going to be a Plex issue as they produce the app, I know users not just on LG but other platforms as well who have had issues .  If you are prepared to try something else then have a look at Emby,  I have been using it instead of Plex for about a year now and have found it stable and an excellent replacement for Plex.
What issues are you having. Plex server runs on in my Mac and works flawlessly with my webos tv... No issues whatsoever.... Even streaming large uhd / 8k media is perfect.
I would encourage you to read the Plex data base and fine tune your server.. It should work great!
Otherwise try to get lg to replace the remote.
The problem is in the plex client that is specific to lg on web os.  I think I already posted the exact version number on the plex forums.  Works fine on roku but the plex client version specific to lg prevents you from using the plex pass dvr function. Everything else works fine.   I smell a rat.
2 minutes ago, Lgrump said:
The problem is in the plex client that is specific to lg on web os.  I think I already posted the exact version number.  Works fine on roku but the plex version specific to lg prevents you from using the plex pass dvr function. Everything else works fine.
Are you recording to an external hard drive attached via usb to your tv? Mine works fine as long as the drive is fat32 forrmated
The exact problem is that on the dvr screen the mouse select on the remote will not launch a recorded item. Plex for lg client version 5.57.2 platform version7.3.0
I am running the plex media server on ubuntu 22.04 and have an external drive formatted as ntfs where the media is stored.  I have a hd homerun quatro where I record digital hd unencrypted signals coming from local  stations via a hd antenna.  Its not a plex server issue.  Its a plex lg client issue.
4 hours ago, Lgrump said:
Will the title of the remark is misleading "Plex is unusable". Plex send very usable with one function disabled or not working.
If it is a Plex issue, ask Plex to resolve it. If you are a Plex Pass user they will reply to you quickly.
It may be a localised DRM issue but mine works fine
