Browser version too old or incompatible
By keshav iyer
By Alex Benet
Hi everyone, I have a recent problem with my lg smart tv web browser. TV's model is 50UH635V and I've noticed that the browser can't open certain websites showing the message "the browser is no longer supported". Is there any solution to this? Can I install a 3rd party browser to my TV, like mozilla, chrome, something like that?
By NaveenKumar
Latest version of sun NXT app version 8.0.20 is not working for web os Tv version 4.4.2-11 plz do the needful full & Airtel Xstream is not found in your web os platform kindly check on that too
By majorusa
- 3.23.24 - Romania- 47LB730v
By Steve D B
Hi, my LG webOS TV TN520S is running software version 05.45.45 and since then the channel 4 and channel 5 apps are broken. You can start to watch a program but as soon as the first set of adverts start, the app just loops and you cant progress past the adverts. I a wondering if this is because the TV is running the latest version of its software (I've searched for newer versions but none are shown). Has anyone else had this problem and is it possible to install a previous version of the TV's software to see if this resolves the problem.
Sylvie G
Hello
When I try to watch replay or live TV from Belgian casts in the browser I have error messages:
- for Auvio (RTBF) it is purely incompatible
- for RTLPlay , the message says that the browser version is too old and has to be updated.
But...
It is impossible to install alternative browser on LG smart TV, or to update the LG one.
WebOS is not really a good idea, or at least it should be more "open" for the apps that are not proposed or updated.
I know it is possible to share from other machines (tablet, phone or computer) but I want to use my TV "alone" too!
Do you have a solution (other then buying a chromecast or equivalent device?)
Thank you
