I've seen an older thread on this topic but it doesn't look like anyone found a solution to disabling the screen saver, so I'll try a new one.
On virtually all my LG TV's (I have three OLED's and two LCD), the screen saver interferes with my music app (like Plex, Spotify or Amazon Music). I mainly use Plex for playback of my music which is stored on a central server (NAS) and from the app loaded on a Fire TV stick or cube. After about 20-30 minutes, the album art and other related music information (lyrics, song title, duration, etc) all goes black. If I run Plex (or Spotify) directly on the LG TV via the LG Content store app, the screen saver with fireworks always comes on in about 2 minutes.
I've tried all the different methods to disable the screen saver function including turning off the Timers, Auto Power Off,  HDD Storage, etc. I also tried opening the hidden menus by pressing the mute button 5 times but that menu didn't have anything relevant.
Interesting is that the screen saver doesn't come on when using Spotify on a Fire TV stick or if I playback music through a USB device. But i don't use those methods often, mainly Plex to access my music server where I have about 500 CD's stored in ALAC format.
Has anyone found a way to disable the screen saver function? I know the logic for having it (to prevent OLED burn in) but I'm not leaving the same image on for more than the song duration (about 3-5 minutes).  It's annoying to check the screen for the a music title or see who is on only to find a black screen looking back. Thanks for any help.
Has anyone found a way to disable the screen saver function? I know the logic for having it (to prevent burn in) but I'm not leaving the same image on for more than the song duration (about 3-5 minutes).  It's annoying to check the screen for the a music title or see who is on only to find a black screen looking back. Thanks for any help.
Hello friend
I have a technician-Remote,  and tried to go through all menu-settings. Couldn’t find any disable-function.
Thank you for your reply. I kind of thought that was the case, but just wanted to see if anyone might have found a way. I do understand the issue with OLED burn-in, it happened to me a few years ago and LG was great about replacing it. So they probably want to limit their exposure to the possibility of it happening. I just wonder why other OLED manufacturers don't force you into screen saver mode. Anyway, thanks a lot.
  • 3 months later...
You can go to the Settings section on your TV, then find the screen saver to disable it.
Or, you can try to use USB drive or other methods to play Spotify songs on your TV. In this case, you have to get Spotify songs to a USB drive first via DRmare Music Converter. Then you can have local Spotify music and play them offline anywhere.
  • 3 months later...
Press the mute button 10 times to bring up a hidden menu, there will be a toggle switch to turn the stupid screensaver off.
I use my TV as a PC display and this was driving me crazy, kept popping up when I was scrolling through websites and watching films (even in full screen).
  • 2 months later...
It worked, thank you
  • 2 months later...
Press the mute button on your remote three times. A menu should come up that allows you to disable both the ‘no input’ pictures as well as the screensaver and the LG start up logo.
  • 2 months later...
mute button 3, 5, now I hear 10 times?? of which none of them put into another settings menu. the real goofy thing about LG is that there is no model number anywhere on the TV and no menu in settings to turn screen saver off LG just is no good! I have to use usb for a commercial building directory and screen saver always comes on with fireworks
  • 2 weeks later...
    • By Batman
    • By mycop
      Greetings.
      Transitioning Between Transparent to Opaque Screen, LG SIGNATURE OLED T
      Introduces New Viewing Possibilities and a New Era in Home Entertainment
      SEOUL, Dec. 19, 2024 — LG Electronics (LG) is set for the global launch of the 77-inch LG SIGNATURE OLED T, the world’s first transparent and true wireless 4K OLED TV. This groundbreaking model will be available in the U.S. this December, with additional markets to follow.
      Unveiled at CES® 2024, the LG SIGNATURE OLED T represents a monumental leap in both technology and design innovation, reflecting LG’s relentless drive to delivering new and better. Its cutting-edge self-lit screen can transform from transparent to opaque screen; a unique ability that provides the OLED viewing experience while offering greater freedom in living space. Recognized globally, LG’s transparent OLED made TIME’s Best Inventions 2024 list and received a total of five CES 2024 Innovation Awards, including a Best of Innovation honor.
      Users can effortlessly switch between transparent and opaque modes at the touch of a button, unlocking unique possibilities for entertainment and space design. When in transparent mode, the OLED T offers a futuristic content experience that must be seen to be believed. The screen not only creates the illusion of content floating in mid-air but also produces a mesmerizing effect by “merging” the on-screen visuals with the surrounding space.
      LG OLED T further elevates the user experience with a suite of versatile features that optimally leverage the unique advantages of a transparent OLED screen, enhancing its distinctive value.
      One standout feature is T-Objet, an Always-On-Display (AOD) mode that transforms the screen into a transparent digital canvas, ideal for showcasing artwork, videos or photos in outstanding color and clarity. Complementing this is T-Bar, a sleek info-ticker that appears along the bottom edge of the screen, providing sports results, IoT device statuses, weather forecasts or song title information. The rest of the screen remains unused when T-Bar is active, presenting a clean, uncluttered look and a clear view of the space behind LG’s “virtually invisible” display. For added convenience, T-Home offers a user-friendly interface that delivers a well-organized overview of available services, as well as quick access to apps, settings and other features.
      Despite its stunning 77-inch screen size, the LG OLED T enhances the feeling of space within a room, providing a sense of openness that conventional TVs simply cannot. Its transparency allows it to be placed centrally without being obtrusive or positioned in front of windows without blocking natural light or views of the outdoors.
      The transparent 4K OLED screen, combined with LG’s true wireless video and audio transmission technology, promises not only the aesthetic value but also an enhanced home entertainment experience. Free from tangled cables, the device delivers an immersive, distraction-free viewing environment.
      The OLED T advances innovation with LG’s proprietary Zero Connect Box, a visually lossless wireless video and audio transmission solution* without latency ensuring a seamless viewing experience. By supporting 4K at 120Hz variable refresh rate, OLED T has been certified by NVIDIA G-SYNC® Compatible and AMD FreeSync Premium to eliminate tearing and stuttering for the most dynamic, true-to-life gaming experience.
      The LG SIGNATURE OLED T carries forward LG’s legacy of providing superior picture quality and immersive viewing experiences – hallmarks of LG OLED TVs since the very first model hit the market in 2013. Building on over a decade of OLED innovation, LG’s one-of-a-kind TV brings images fully to life with vibrant, precisely reproduced colors and incredible contrast. Powered by LG’s advanced α (Alpha) 11 AI processor, the OLED T intelligently optimizes both picture and sound quality, delivering unparalleled visual and auditory experiences.
      “LG SIGNATURE OLED T is an exceptional user-focused innovation that offers a distinctive, multi-faceted viewing experience and unprecedented spatial flexibility,” said Park Hyoung-sei, president of the LG Media Entertainment Solution Company. “LG remains at the forefront of innovation by combining its industry-leading OLED technology with unique form factors, transparent screens, wireless connectivity and more, delivering unparalleled, life-enriching advancements no other TV maker can replicate.”
      * Wireless transmission refers to the transferring of video and audio signals between a TV screen and the Zero Connect Box. Visually lossless, based on internal test results with ISO/IEC 29170-2 and measurement results may vary depending on connection status.
    • By Gene680
      It turns my channel off at random times exactly 11 minutes after the hour. I checked and double checked the settings looking for timers, etc. any fixes that I’m missing?  It’s when I’m streaming on Sling.
