LG C2 - nintendo switch & Universal remote
By RJ Fischer
By JasonB
By u84six
By joepineapples90
So I'm thinking about buying an oled65g46ls, however the included 'magic' remote would be useless to me, due to health issues (tremors). So my question is, do any other LG remotes work with the G4?.
SFrank
Actually , i get signal from my nintendo switch on the tv, but i struggle to add configuration with Universal remote menu , the gaming console option is not showing up in the menu.
i saw a lot of advice using device connector app, but unfortunately it seems this app doesnt exist anymore on most recent firmware.
I dont understand what im doing wrong.
edit: i think i m confused with auto device detection & remote configuration. My nintendo switch was not tagged automatically as a gaming console nor named properly but i could change it manually. Then for the remote i m pretty sure there is no ir receiver on the switch itself so …
