Backlit Universal Remote
By JasonB
By RJ Fischer
By u84six
By joepineapples90
So I'm thinking about buying an oled65g46ls, however the included 'magic' remote would be useless to me, due to health issues (tremors). So my question is, do any other LG remotes work with the G4?.
Don Hopper
Is there a compatible Backlit Universal Remote control for 86UQ8000AUB
