DVBT/T2 won`t work after the update (Version 06.10.30) on LG SJ850 series
hello,
I'm having problems with terrestrial TV broadcasts after installing the (Version 06.10.30) software package. The TV broadcasts that were saved are out of order and the search no longer runs as before. Suddenly the search bar jumps from 0% to 100% and no broadcasts are found. Neither radio nor TV. I have tried 3 DVBT2 antennas and two coax cables to see if that is the problem. But all of them behaved the same way on the TV, which is an LG 60SJ850V-ZA. I also tried a full TV reset but that didn't help. I also had the TV turned off for a longer period of time with no electricity, but it made no difference. The release date of the softer package is in December on the site, for me it appeared on the TV (OTA) around late January - early February. Should I expect a new patch in the near future or should I try a downgrade? Any other advice? Thanks in advance for your replies.
I'm currently buying a DVBT2 TV-BOX to watch the channels that are important to me, it's just a bit funny that I need this for such an "expensive" TV (for me). It is not a modern AI piece, but still...
    • By mean2
    • By OliverRC
    • By David Daul
    • By Ajothen
    • By Horniak
