Searching for programs across apps using magic remote or voice control
By thewookiewon
By RJ Fischer
By hollean
By Pranay Mokida
Jeffrey Rapp
I recently purchased an LG OLED48C2AUA. Frankly, I'm not pleased. The biggest problem is searching for programs, particularly across apps. For example, if I'm in Netflix, and search for a program that happens to be in Prime Video, using voice control (Alexa or LG) or the speak button on the remote, I usually get random UTube trailers or other suggestions, or no suggestions at all. It seems I have to know in advance what streaming app it's on, and even that doesn't work all the time. Before purchasing this TV, I used to be able to immediately find the program using the voice control on my Xfinity remote, or the Roku remote (if the program was on a streaming service) and my "unsmart" Sharp TV, with the input set to either cable box or Roku, as appropriate.
I don't want to have to know in advance what app the program is streaming on to find it. I want to be able to simply say "Alexa, show me "Boardwalk Empire", no matter what program or app the TV is currently tuned to. I want the complete list of possibilities to choose from, particularly since some may be free, depending on my subscriptions. Is this possible?
