LG G2 65 turns off when using PS5
By hollean
By JamieG
By Gene680
It turns my channel off at random times exactly 11 minutes after the hour. I checked and double checked the settings looking for timers, etc. any fixes that I’m missing? It’s when I’m streaming on Sling.
By leodavid
I've recently purchased a WebOS TV UK6400PVC and magic remote came with it. The software version is 4.10.30.
The buttons work fine but for some reason, I can't get the cursor to appear on screen.
Appreciate the help. Thanks
Richard Marchlewski
My LG G2 bought last November has now started to turn off every 10-15 minutes when gaming on my PS5 which is directly connected. It also from time to time identifies the PS5 as a different device (Shield TV). Any suggestions on how to fix would be welcome.
