Hello team,
I bought LG web OS smart TV but i did not satisfied for having smart TV as LG
Bz other app having at Android those could not installed eventhough like same app not available for web os platform and also other app will not  support to this system which I want.
If you're looking for more flexibility and a wider range of apps, have you considered using external devices like a streaming stick or box? For instance, you could connect a device running Android TV or Windows to your LG smart TV. This way, you can access a broader selection of apps and enjoy the functionalities you desire.
Speaking of enhancing your system, have you ever thought about sprucing up your computer with some affordable W
? I recently came across a subreddit that offers discounted OS keys. It's worth checking out if you're interested in upgrading your operating system at a pocket-friendly price.
    • By SHawk
    • By NaveenKumar
    • By Guy C
      Hi, I've got this model LG which is updated to webOs 3.9. I can't connect an iPad wirelessly as it needs airplay with comes with webOs 4 but I think my TV was just pre 2018 when it changed (mine must've been the outgoings model). Is there a way to force an update and should I do it if I can?
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
    • By Steve D B
