AV connection pop up
By akhil7j
By Trung Hiếu Trần
Specs: LG OLED 55C3
Router speed: 250mbps
System: webOS 2.3
Any ideas on how to fix it?
By makem
I have a LG OLED55C14LB WebOS TV in the same room as my xubuntu desktop computer and router.
By JohnS
New user on here.
I bought this new TV last week and it is honestly driving me bananas.
When I click "Home" after using an App, etc, it brings me to the WebOS interface but then automatically selects the last used device (e.g. Fire stick, LG Channels, etc) despite me not wanting it to.
Is it possible to disable this, i.e. "Home" brings me to WebOS and stays there? I'm sure its a setting etc which I'm missing.
Device is LG UQ91 43 inch 4K Smart UHD TV, pretty sure its all up to date.
Thanks in advance.
By Bob17821
I have problems with one of my WebOS TVs which looks like a speed problem, but when I do a speed check on my iPhone from just a few feet away the connection speed looks fine. Thanks, Bob
