App Review: Finger Notes
From the dawn of time, man has had to find a ways to write down his thoughts and reminders in order not to forget them. From the paintings on the walls of caves by cavemen; to the detailed hand writing on parchment paper with ink and a sharpened quill. Fast forward to today and we've made the grand leap from parchment to little neon-colored squares or paper we can stick to things. What a marvelous age we live in where we can afix reminders to the refrigerator, the mirror, and the door when you leave for work. Wouldn’t it be great to have the color and fun of
without forgetting them and the expense of rebuying them?
Allow us to introduce you to , by Middlemind Games. It's a very simplified webOS notes app that lets you add your own creative touch now available for the TouchPad. There are other note-taking apps out there, like , , , and even the built-in webOS Memos app, but what Finger Notes provides is simplicity and ease of control with the use of just one finger. But using just that one finger can be limiting - Finger Notes isn't an end-all solution for quick notes, and it certainly isn't perfect.
a2t.imgeCgUlWC_5YE
    • By Alex
      the viewer sits.
      Source:
    • By Alex
      KEY FEATURES
      LG OLED65G7V – DESIGN
      LG OLED65G7V – FEATURES
      Related:
      Related:
      VERDICT
      OVERALL SCORE
      SCORES IN DETAIL
      Read more at
    • By Alex
      Thanks to @Peter Alexander and @SSM we have confirmation of webOS 4.0 compatibility within the release notes and information listed for their respective apps in the below topic.
      We've confirmed the iOS version changes:
      We've also confirmed Android:
      Both version updated were added this week. We are waiting for an official webOS 4.0 press release from LG and additional information on what models are supported.
        Q10 in 90 minutes
