LNB short
By leader6234
Hey guys !!!
Thanks in advance !!!
By jinsonkv
Any personal opinion about this projector? Through a
link hidden, please login to viewReview page, I read that, since this projector only has USB 2.0 support, it affect the streaming of blue-ray movies through USB. Is that correct? Then why LG didn't place USB 3.0 or 3.1 support? Share your view...
By Kiran K Telukunta
After updating to 5.10.10, remote short cuts in Youtube does not work any more. Would be great if resolved.
By Alex
LG HF85JA Ultra-Short Throw Laser Smart Home Theater Projector
Full HD Resolution
Watch movies and more in true 1080p high-definition sharpness, full of the fine detail that can be lost at lower resolutions. The picture remains lifelike and text is crystal-clear when displayed at up to 120 inches or more
LG Smart TV
LG's exclusive Smart TV platform is simple to set up and offers easy discovery of exciting premium content from the most popular providers.* The included Magic Remote makes navigation fast and fun.
Found out more:
By Alex
The LG HU85LA 4K UHD Ultra-Short Throw Projector is coming soon and due to be released at CES 2019.
Fatfrog
Hi all
LG UHD TV 55UN71
Have lost some channels with message "TV signal has been lost due to satellite lnb short"
Message also shows briefly on working channels.
The satellite lnb feed works perfectly with numerous other satllite receivers, just not on tv.
So its something to do with TV, I've reset channels, I've reset to factory settings, nothing gets it to work.
Any thoughts please?
